Greetings All,
Bob S., When the Pile was acquired, I did an immense amount of research. I knew the engine was going to be problematic, but not insurmountable, but just in case… fate was kind to me. I was eventually able to purchase a Jaguar Pushrod OHV engine, 3.5 liters and later a 2.5 version. That is Plan B.
I purchased a NEW aluminum head made by a gentleman out in Australia as the original heads had questionable metallurgy along with a tendency to collapse internally because of their age and corrosion after 75 yeas.
I hope purchasing it was more than wishful thinking regarding getting a correct engine.
While the 3.5 will fit, it might be more than the cable brakes are capable of handling.
Early on, I had a chance to purchase a Standard with the correct engine and obviously a bunch of period parts that could have been used.
Unfortunately, I have a conscience, the car was an older restoration that ran BUT it had matching numbers and I didn’t want to be “That Guy” who parted a survivor vehicle.
Currently car sits on 4 wheels now, though the rear end is a hybrid. The engine swap from a previous owner overpowered the differential. The crown and pinion suffered so the diff was sectioned and a new meatball from a Dodge appears to have been spliced into the original.
I say spliced, as they wanted to keep the wire wheels and brakes for looks, so the cut the center our and installed the stubs from that into the Dodge housing.
I managed to find a correct differential housing along with a crown and pinion assembly.
Pictures…third one is frame, in white because I plan on marking it up as trial fittings are made.
Other two are cowls. First one is mockup of cowl in oak and plywood. Made this as there are so many dimensions that are critical for the rest of the build and I wanted to make sure they were right before committing to building the actual cowl out if marine ply and black locust. The wood is an upgrade because of its shipbuilding qualities.
The other pic shows an original cowl that was used for a pattern and mine. Mine is symmetrical, the original…not so much.
Currently looking for rear axles. Possible vendors, let me know.
