Main Bearing cap loose!!!
Just had a very strange occurrence in a customers car.
The car is from undetermined lineage and history. Nice overall condition, but overheating and running like a dog (Car came in on a flatbed) Customer got a great deal, but suspected it needed some work.
Basic checks showed a poor/non existent spark.
Compressions were OK - not spectacular, but OK, a little down on one cylinder, but nothing to get dizzy about.
Distributor was so worn that we couldn’t realistically set the points.
So, new (electronic) distributor fitted, and she started up instantly.
Timing set, we gave the carbs a quick checkover (balance checked and mixture set.).
Car sounded really good. The valve clearances need to be done - a little noisy on the top end, and a little lumpy running (I suspect some worn carbs).
Oil pressure was a bit low on the gauge, but the oil light wasn’t on (but does function) - all the instrumentation is flakey on this car, and is going to be checked through.
So we go out for a test drive.
Car drove really really well - pulled like a train, and was very smooth.
Overall, I thought, this wouldn’t need much work at all!!!
Thermostat has been removed (temp not coming up)
Then, a tinkling sound - sounded like a pulley coming loose.
Pulled over in a garage, engine idling, and “clunk - tinkle” - it spat out number 4 (I think) main bearing cap through the side of the sump, complete with the Bearing cap bolts.
What the hell?
Bearing cap bolts haven’t pulled out - the witness marks on them look like that have been coming undone for a long time, until the crank has caught the cap and spat it out, and left a slight gall mark on the very last thread of one of the cap bolts.
No signs of overheating on the cap (but very obvious signs of the collision that pushed it out the side)
I have never seen this before - ever.
Has anyone out there seen it.
I initially thought that the lock tabs had been omitted (last jag engine I built was a 3.4 in an XK120, and they had lock tabs originally). But it seems like the S1 4.2 didn’t have lock tabs, am I right?
The car is otherwise sound - but the rear of the engine is suspiciously dry - I suspect that a rear oil seal conversion may have been done, and this is perhaps when the cap wasn’t tightened properly.
I’m pretty sure I can fix it - but this failure is a new one on me.
Anyone else seen it?
I’ll post up some heartbreaking pics when I get it up on the ramp…
