A bad condenser is very possible, an internal short could cause cutting out. You can actually use a generic one, and if you need to mount it outside the distributor, it will work fine as long as the circuit connection is the same. Body grounded and small wire on the external connection terminal or even on the coil CB or + side.
No engine number can mean two things;
- It could be a replacement block ordered from the factory back in the day. They used to have an exchange program, but whether they turned them around with or without a new number, maybe someone else will know.
- Someone wanting to hide the fact that it came from a Mark V, and might be looked upon as tainted by a buyer, non-original, which would affect the price.
For that matter, it could have come from a Mark V under the #1 scheme above.
There were a few slight improvements over the years, though on external and internal parts. There was only one change to the block, C.314 to C.314/1 and the nature of this change is obscure, awaiting discovery. Might be the location of the dipstick?
If you really care, we can investigate further.
