No clue on the milage. Odometer says 10, but something tells me that’s wrong. The tires look like they might legit be 50 years old. I bought the car in an estate sale. The executor (daughter) said dad bought it 25 years ago, parked it inside and never touched it again. That looks to be the case. The interior looks all there and straight but is so brittle that it will crack if you look at it wrong.
Powertrain is not running and I have no idea of the condition. I would assume full rebuild of engine and trans required. Based on the condition of the rest of the vehicle, I’d expect the insides to be mostly still usable.
Scope: engine, trans, carbs, exhaust, fuel tank, driveshaft, basically everything that makes the car move except the rear end and radiator.
Engine code is listed as Z3096 and gearbox as JH4036. I can’t verify these on the actual engine and trans because I’m on crutches for the next week (also don’t know where to look).
I can take the valve cover off and shove a borescope in a couple cylinders next week but I’d rather not do a bunch of disassembly.
possible concern: It looks like a valve cover breather is missing and open to the environment, and the carbs are removed with rags shoved in the holes.
Pics here: https://imgur.com/a/Cu35REw
Let me know if you have any specific pictures you want to see.
