Mark V Velvet Strips on Doors
The Mark V Saloon Body Section lists these: BD.2700 front (2), BD.2701 rear (2), these are Velvet Strips Between Glass and Doors, and BD.2701/1 (4) Velvet Strips on Garnish Rails. The DHC has BD.2701/2 (4) on Each Side of Glass.
From what’s left of mine I would say they are like black velvet piping sewn with a strip of steel inside.
Has anyone found a source for this stuff?
I tried Worcester but no luck.
Perhaps look at Steele Rubber Products. They have several offerings, none specific to Jaguar. Some examples at Steele Rubber Products - Window Felts and Run Channels
And maybe Rubber the Right Way beltline weatherstrip such offerings surrounding https://www.rubbertherightway.com/i-30505634-beltline-weatherstrip-also-called-window-sweeps-felts-or-fuzzies-pair-of-3-strips-inner-or-outer-7-16-tall-1-4-wide-stainless-bead.html
I made my own as faithful replicas. I found a suitable rubber section at the rubber place, then cut strips of half mm galv, and wrapped the assembly with black velour. I match drilled the galv strip for the tacking points. I glued the galv to the rubber then likewise the valour.
The bulb of the rubber is slightly larger than the original, but it was a bit misshapen with perishing. Works well, no draughts sneak past and loksas good as the original.
I omitted to say that mine is a Mk IV but the V could be similar.
You can try BAS JAGUAR TRIM, https://basjaguartrim.com/. I bought the entire interior from this company.
Try woollies in the UK
https://www.woolies-trim.co.uk/
Got mine from Woolies - under their “Window Seals and Weatherstrip” section:
I found one original remaining on my interior wood trim piece in fair condition, good enough anyway to get an idea of what they were.
