Hi Jag Lovers,
Recently purchased a used but perfect right tail light assembly with lense for 2000XK8.
Can anyone help me with steps to remove old assembly and install replacement?
Thank you
Hi Jag Lovers,
Thank you
If I recall correctly it’s pretty straightforward. Pull the back bulb cover off and undo nuts. It’s been a while though
Thanks Jason,
It turned out to be very easy. Need to watch the rubber gasket for distortion before tightening retaining nuts.
Otherwise, just like the instructions.
Martin
"05 X-Type Estate Wagon
'00 XK8 Coupe
