MK 2 Crankshaft trigger wheel
(Phil.Dobson) #1
Just wondered if anyone has mounted a crankshaft trigger wheel to a standard Mk2 crankshaft damper? and if so what bracket are they using for the pick up. some photos would be much appreciated.
Best regards
Phil D.
(tapped) #2
Phil – see this post: Ray’s EDIS and AC kit on a '64 3.8 S1
I did this on my Mk2 but mounted the trigger wheel on the backside of the crank pulley. I made a custom mount for the sensor (shown in the attached link) out of scrap aluminum. It’s mounted to a couple spare threaded holes on the left side of the block. In theory I can change the belt without removing the sensor. In reality the bracket interferes slightly with the generator when I fully de-tension the belt. I may fix this before the engine goes in the car. As it is I need to remove the fan to put on the belt.
Setup works great, but was not an off the shelf solution.
Tom
(Phil.Dobson) #3
most helpful, thank you
