In a previous post one of my questions was the meaning of the number on a tag screwed to the inner
boot below and behind the fuel pump. My number was E 009033
One of the replies was this:
pdm75 pdm75 Phil Madeira
November 22
Hi All,
I have a mk2 jaguar 3.4 1961 , this also has the small plate below the fuel pump in the boot . Does anyone know what this number relates to ? it is not the same number as the chassis number or the body number and doesn’t appear anywhere else. My car matches all the numbers on the heritage certificate and on the main plate in the engine bay but I can’t seem to find any information about this small plate.
Can anyone shed any light on this ?
Regards Phil
Recently I emailed the Jaguar Heritage Trust about this. Here is their response:
I am presuming this number is stamped on the left-hand inner rear wing area, behind a millboard panel.
I looked at our records for where numbers are stamped around the vehicle (other than the main identity plate underneath the bonnet.
For the Mark I, I found the following note for the body number “stamped on a small plate attached to the right-hand side of the scuttle under the bonnet”.
However, when I checked the Mark II notes, I found this: Up to 1963 - stamped on a small plate attached to the right-hand side of the scuttle under the bonnet. Subsequent – stamped on a small plate attached to the right-hand side of the body behind the rear bumper. Not to be confused with a similar plate on the left-hand side giving the Press Steel reference number"
These are notes compiled by the factory in the late 1960s. Thus, whilst I appreciate your vehicle is a Mark I, and this is a note for the Mark II, I think, given the passage of time, I find this the most compelling explanation for the number you have found in your vehicle - it is the Press Steel reference number.
I hope this is of assistance.
Best wishes,
Tracy Nabbs
Jaguar Heritage Trust Archive
