MK1, MK2, S-Type Auto-Transmission
Hi folks
Trying to identify the following transmission in these photos. I inherited the parts from my late Father-in-law who was a mechanic.
DG-250-MJ Serial Number JBC 10423
I understand from some good folk elsewhere that it could be a MK2 or S-Type 3.4
I also have a Gearbox for something similar in a another post.
Any help would be appreciated. Thanks in advance.
Andy
This box was used in MK7,8,9, XK140/XK150, MK1/2 and early S-type.
Some variance exists, depending on the serial number.
It uses a special Torq converter with build in clutch.
The center hole of the input shaft should contain a tube to engage the clutch
Many others will probably chime in and note that this DG250 is a weak transmission and exttremely expensive to work on , let alone find someone versed in their repair. For the money you would be better off going with a 700R4. Others can suggest good modifications please.
Thanks very helpful
