Hmmm. Definitely missing some parts. I’ll get another look at mine sometime today. Those photos are very helpful - thanks for subjecting yourself to the grass stains on my behalf.
I’m in the middle of building a 1000sq foot greenhouse on my property, and will be tied up with that until next week, so won’t get much done on the car until then. I did send the series 2 XJ master and servo off for rebuilding yesterday, don’t expect to have them again for about 6 weeks. Based on your advice, I’ll likely not change rear brake systems, but will have to see what I have on the car and in the parts stash. I’m thinking I will pull the rear end on my 4-post lift, but it’s tricky because of the width of the unit. Since it’s wider than the ramps, I have to drop the suspension on a rolling dolly, get the rear of the car pretty high, and swivel the cage 90 degrees before raising the lift. I’ve done it on my e-type. If I decide it’s risky, I’ll have to wait until I have front brakes so that I can move the car. Right now, it doesn’t even have a parking brake.
Ok, it appears that I’ve got most of it. The front bracket and insert are there, and I think the middle one may just be missing a bolt. There is nothing at the rear site where the cable casing is retained, so I may have to find that.
I dont think you will have too many hassles, and have the Parts Manual pic ?
send me a good description of any parts you want, as I will be under one with an angle grinder in the not too distant future, might be able to find what you need, if anything
That’s really generous of you. Let me get into it and I’ll PM you when I figure out if I need anything. Probably a week or two at best. As I look at your photos again, I understand better - looks like the cable housing clamps into the rear bracket. I’m assuming the new cable comes with the housing. If I have right stuff on my spare rear suspension, I might just need springs and a bolt which probably can be sourced locally.
I’ll have another look, but I think everything in front is there. My back order of parts including the cable got mailed today, so I should know soon about the cable housing in a week or so.
If the case has a band clamp around it like the remote boosters used on the e-type and Mk2, they aren’t bad to rebuild. The more modern cases, just forget about it.
