Hi fellow Listers.
I’ve had an issue with my REV Gauge for some time, flickering & now finally has stopped registering!
I did a voltage check on the generator terminals with the engine running & it was all over the place. Removed the unit from the cam cover & bench tested it with a drill. Voltage again was erratic going from +3V to -!.5V & everywhere in between.
The unit had been crudely repaired 30 years ago, so I removed the old plastic filler to find one of the brass contacts separated from the bakelite & a piece of the bakelite missing.
When I unscrewed the bakelite section I discovered the insulation plate holding the two contact springs was broken as well.
See photos.
I’m having trouble finding a good S/H unit, I’ve contacted a number of gauge/instrument repairers & not surprisingly no one have parts for these units.
The tang/drive dog has only 1mm longitudinal movement so the engagement to camshaft should be OK.
So, I’m considering having a go at repairing this original unit.
The bakelite can be fixed with modern epoxy & shaped to size, & I’m thinking of using some Micra Sheet from the local electronics shop to make up the small broken insulating plate.
Will be fidley I’m sure.
Has anyone had a go at repairing one of these units & can offer some guidance?
cheers
Pierre
The only repair I have done with these is to pin the armature so it does not slide back and disengage from the drive dog. I think if you are skillful with epoxy J B Weld and a Dremmel tool you should be able to recreate the broken piece.
If you’re in Adelaide, try Geoff Mockford at https://classicsportscar.com.au/, Bob Anderson o4o8 8o4 28o or Alan Baker, or EVAN SPARTALIS Phone 8362 8116 Mobile 0408 827 919 12 College Road Kent Town.
Thanks for your replies, guys.
Andrew, I know Geoff & Evan very well & caught up with them both Friday/Saturday.
Geoff only had one S/H & that was U/S.
Evan had one that he was uncertain of its condition, but he kindly swapped it for mine & I fitted his yesterday.
At first nothing then a tap on the RPM bezel & it started registering.
I’ll need to get behind the gauge & just check there is not a loose wire contributing to the issue, but so far, it’s a big improvement.
That would be a help for the original unit Phil, but they don’t post to OZ!
Noted Mike.
PS:- Might need to send you my clock one day to get that working as well!
