I believe this is the important measurement to compare, how much bite / crush / pinch is applied to the centre plate when assembled, if anyone else with a spare 9 1/2" diaphragm clutch can check the distance the centre plate sits above the cover mounting surface it would be a great help, I have several similar new BMW clutches and will measure a few of them for comparison,
I have several other threads running! I think the restomod thread has been updated with me finding the left side lower chain guide laying in the oil pan! I managed to remove the front cover and have ordered a new guide, whilst I had this lot apart I thought I would tackle another thing that had been bothering me, my engine is from an XJ6 and so had the larger water pump impeller, I tried to remove the one from the XJ6 water pump and fit it to the new Mk2 pump but the impeller broke onto several pieces, I just fitted the Mk2 pump as it would probably be ok, I found that you can buy an XJ6 size impeller for little money so have ordered one, hopefully I can make it fit the Mk2 pump,
