One last time please. Is there consensus on the front suspension settings for a standard mk2 using modern radial tyres. Rebushed suspension using pollybushes
Once I found a writing, that when using radial tyres, you get better wheel alignment when
you turn the top upper wishbone mount around.
This way the mount points of the top wishbone will be ( about 1cm ) lower.
I have done this many years ago, great handling ever since.
Also installed pollybushes.
peter Jan
