I am looking for more projects , modifications I can do to my car , or have I covered most things ?
At the moment I am looking into making a Towing eye , to bolt to the Bumper Iron .
List of mods so far .
Fully reconditioned XJ6 3.4 Engine
Copper HT leads , sports coil ,
Uprated rota arm
2" HS8 SU carbs
Mechanical Oil pressure gauge
E-type factory lightweight flywheel
Uprated Radiator core
Electric cooling fan
S-Type Auxiliary water pump
Kevlar hoses
Sincro gearbox with overdrive
3.54 L.S.D Axle
Close ratio steering box
2" straight through Exhuast
XJ6 6" rims 215/70-15 P4000 tyres
Bearing control arm bushes
Moto lita steering wheel , alloy horn push
Air horn
Lowered uprated front springs
Lowered spring mounts
Polycarbonate rear spring spacers
Poly bushes
Uprated rear spring mounting plates
Rear Anti roll bar
GAZ adjustable dampers
Braded clutch and brake hoses
Copper Nickel brake lines
Kill switch
Narrow rear spats
CD player
Sat nav socket
Door mirror
EBC Greenstuff brake pads ,
Leather seats
Towing eye
I think that’s about it , if I think of anything else I will add it to the bottom of the list !
I was quite happy with the brakes , before I fitted the EBC Greenstuff pads , they are meant to give 15-20% brake improvement , but better then what ?
Plus just replaced servo .
So not looking to replace the Calipers , no point in spending £1000 , plus I have some cooper craft and Volvo 4 pots laying about !
Looking at the list , electronic ignition is missing , I did have Lumanition on a GT6 , was very happy with that , so may look into that .
Looking for other bolt on modifications, or improvment’s, with pictures, would be nice
Car started life as a 240 Auto , some may say it’s not a MK2 !
