I remade the saddle under the grill. Sharing the work earlier a poster reminded me to make the notch in the middle. I put it in the back of my head and forgot…
So I have finished painting it and then it popped to the front of my head when I saw a little pool of water in the middle of the saddle after giving the area a quick wash.
Is this a critical drainage feature I need to put back. Perhaps just drill a hole through ?
I thought that the notch was needed in order to provide clearance for the grill center vane to pass through the grill opening as the vane mounting hardware is proud of the peripheral mounting flange when assembled. If yours fits, I don’t see a need to put one in.
Relative to water pooling, when I rebuilt my saddle area, I drilled an 1/8" hole in the underside panel to provide a route for water egress from the enclosed box section. I did not drill any holes in the upper surface as I am trying to keep water from getting in. I seam sealed the area and fingers crossed, she’ll be good for a long, long time.
I had a look at our car last night after reading your comment and confirmed that our grill needs the notch for the center vane to pass through. Our grill would not fit flush without it.
