Hi All, I am missing the vinyl covered panel that is fitted under the glove box and above the toe boards on my LHD MK 2. I am restoring the interior of the car and I need to send a panel or a template to OSJI for recovering. Does anyone have a spare or is anyone willing to make a tracing of this panel? Any help will be greatly appreciated. Thanks
Mark,
I have a 64 MKII, and will be more than happy to make a tracing of my under-dash panel. However, I’m on travel right now, in Seattle of all places !!! I can send it to you after next week.
BTW - I’m going to see Reece at OSJI in about a month, I’d be happy to take my panel for them to use as a template.
Thanks so much. My car is a ‘63 so your panel should be the same size. Let me know when you’re home and I will send you my mailing address. I am sending a number of panels etc to OSJI in the next few weeks, so maybe it would work out to bring your panel in as well. Either way I appreciate the help.
Hope you are enjoying your time in Seattle. Sunny today!
Hi, Sounds like you are enjoying your time in Seattle. If you have the time, Mt Rainier is worth the drive. Some nice day hikes from Paradise Lodge.
I sent you a PM I think? Please let me know if you got that. Thanks again for the help.
I also have been looking for that panel.
Aldridge has pictures on their site and for sale covered in vinyl.
I’d really like a picture of what is underneath the panel:
Is there a piece of thick insulating felt right above it?
Is there a cardboard tube running from air vent running up to the defrost outlet?
The red-backed jute is original, the tan-colored piece is surplus underfelt from OSJI’s kit.
There was no insulating felt on the backside of the panel.
The heater tubes you mention are corrugated cardboard, and run from the under-dash heater box, along the sides of the center tunnel, to the rear vent box. I’d take a picture for you but you have to remove the front seats to get the tunnel out !! However, below is a photo of a photo I took during restoration, showing the tubes and the original location of the jute padding.
No you don’t. Like Service Manual Page N.22 says, you only need to remove both seat cushions (not fastened, just lift up) and slide each seat as far back as possible. And then remove tunnel fastening bolts.
Köpi
Yes! Just installed my finished panel last week. Send me your address and I will mail you a paper template. You will probably need to make a few small adjustments before covering the panel with vinyl. Cheers
Hi Roy, Aluminum was used only on the driver’s side. All other panels are 1/8” fiber board and covered with vinyl. I traced a neighbor’s panel on cardboard and then trimmed it to fit as closely as possible. You should do this after carpets are installed. I sent the cardboard template to OSJI, and they covered a fiberboard panel in vinyl that matches the rest of my panels.
