how far away from No6 ?
remember the cams turn at half the speed of crank
how did your compression test go ?
have you checked the level of fuel in carb jets as I mentioned earlier…this is quite easy with a bright light and magnifying glass, also in the drillings of the ASC (take of the triangular metal cover if you have one)…it still should cough on ether though
finally, as i mentioned before, make sure TDC is on compression stroke
if not, you will have to reverse wires 180 degrees…guess how I found that out !
ran that engine for over 10 years that way
