I will this week…the MK7 must be different to the MK9, as I have taken wings off several MK7, no spot weld, no lead…I will take photos
I support your idea of removing the wings (if they need any work)…with the proviso that there probably is a heap of lead in there…are you capable of, or intending to re-lead the joint?
Thanks, Tony. There seems to be different information provided about whether mk7s are the same as mk9, but I’ll take what I can get. I do everything on the cars including engine and mechanical rebuilds, electrical, paint and body, and upholstery. I spent three weeks last year in the shop of Wray Schelin learning coaachbuilding skills - while I would look for a better solution than replacing leadwork, I could do it if required. Although it’s wonderfully versatile (I worked in an uncle’s body shop when I was a teenager where he did some lead work) and I’d much prefer not to deal with the toxicity. For the purpose of easy access to the engine compartment for sheet metal and welding mods, I could even probably just remove one fender, as long as everything else was a bolt-up. If they put the fenders on like an xk120, forget it. Definitely not worth it.
here is 2 pics of MK7 guards, one on the vehicle is just bolted on, not welded
The old one sitting free shows a hole near the front.
I do believe it may be that a fastener of some type penetrates that hole from below,
but I could be wrong. and it may be evidence of 1 spot weld at that location
Thanks, Tony. As you know, I’m pretty preoccupied with the Mk10 project now, so won’t be thinking about the mk9 much for awhile. I had an interesting experience with the mk10 fuel system a couple of days ago that I will post separately.
lol, I didnrt even realise you were the same fellow
just came across the pics when transferring from my camera to laptop storage
going to go work on my 420G right now, I have done a complete rehab of the front DS door, (including making a new door card…what a time consuming job that turned into)
I am about to have a crack at an fg xr6 full transplant, will let you know how it goes, It already has a 4.1 crossflow ford in it so hoping the change will be a bit smoother.
Hi Tony , just reading an old post where you said you had a wrecked mk7 . I’m missing a couple of those little blue panel light covers . I don’t suppose you have them ?
