Hello again,
I was wondering if there was an engineering reason as to why the top radiator hose has two different sized ends? Is for thermo-syphoning or something similar? Just curious.
Cheers,
Tim
Hello again,
Cheers,
Tim
I think the hose has two sizes because the radiator outlet is one size and the thermostat housing is another size…
(Sorry Tim, but I had to say it )
Yes, you did and I did think it too. However, I’m hoping that there is an engineering solution worthy of the variation in sizes other than two component manufacturers supplied different sizes. I’m hoping that it has something to do with syphoning which aids the flow of coolant but that might just be wishful thinking.
Tim
Ha, ha. Ok here’s a theory from a mechanical engineer, and if you think it has any value you can insert a coin in the slot_____.
Nothing to do with syphoning, but having to do with thermostat design.
Going back to the SS1, it had no thermostat nor any bypass.
Thank you, Rob, a very well considered proposition. I was hoping for something clever that Jaguar thought up but as you say, “hoo nose?”.
So it seems that Jon might have been right after all! Sir Bill was certainly not one to waste anything.
Tim
As good a hypothesis as any!
A little known related fact:
About 100 of the first alloy XK120s had the starting crank handle and special hole in the radiator to accommodate it, but 10,000 XK engines in XK120s and Mark VIIs had the crankshaft damper bolt with 3 jaws to fit that handle.
One time at work I needed a box of 100 screws, and my purchasing clerk ordered 100 boxes of 100 screws.
Did he also order several Verbal Agreement Forms at the same time?
Tim
Betcha never needed to order those screws again!
