For 1994 XJ40s here is the line-up of the relays on the
firewall. This information is hard to find as it is not
covered for 1994 in either Haynes or the factory service
manual, and it is different from 1993. My dealer got it
for me from a special Electrical manual for 1994.
This information applies to the XJ6 and I believe also to
the XJ12 but am not sure. There are seven relays in total,
and starting from the center and moving towards the right,
the relay functions and connector colors are:
EMS Ignition On White
Breather Heater Blue
Trans. Power Violet
Air Injection Red
(space)
O2 Sensor Heater Yellow
A/C Comp. Clutch Green
EMS Main Black
Of these, all except the A/C Comp. clutch relay must be
replaced with the new black Hella relays (and even the A/C
should be). I don’t have the part number for the new
relay, but the Jag dealers have them and they are not
expensive.
-David
1994 XJ40 4.0L__________________________________________________
Do You Yahoo!?
Yahoo! Mail - Free email you can access from anywhere! http://mail.yahoo.com/
REM----- Original Message -----
To: modern@jag-lovers.org; <@R_Mahoney>
Sent: Friday, September 08, 2000 1:33 PM
Subject: [modern] 1994 Relay line-up
Trans. Power Violet
Air Injection Red
(space)
EMS Main Black
expensive.
-David
1994 XJ40 4.0L
Do You Yahoo!?
