Unfortunately, this is no Chevy! Jaguar bolts their driveshafts on at both
ends. When you remove the bearing mount plate, make sure you recover the
shims. You will have to disconnect the handbrake cable for clearance. The
center u-joint will have to come apart to do the bearing so buy three &
replace them all at the same time.
Phil Prince
