Hi, my name is Manny. I’m pretty much still new with owning a Jaguar. I have
1988 XJ40 w/ 148k on it, and so far no real problems. But just recently a
warning message appeared on the computer…saing Circuit 1 failure. Can
anyone give me a clue as to what that might relay to? Thanks in advance.
Circuit 1 failure is a blown fuse in the (i think)passenger side fuse box.
Jim Moore(88XJ40)
Hi Manny
Be careful about description of Fuse Block locations - depends whether you
are thinking about RHD or LHD!
Certainly for a UK RHD car Circuit 1 Fuse Block is on the RH side (by
driver’s feet - directly under bonnet release catch) whilst Circuit 2 Fuse
Block is in a mirror image position at the LH side (by passenger’s feet).
Circuit 3 Fuse Block is the one inside the centre arm rest/glove box.
The warning messages mean that one or more of the fuses in the Fuse Block
referred to have failed.
Of course, if they keep failing another story starts as to tracking down
what may be wrong (I can give you a list of all the fuse functions if you
need them).
Paul '88 XJ40 Sovereign. London. NW7.----------
To: modern@jag-lovers.org
Subject: [modern] Circuit 1 failure
Date: 22 May 1999 07:42Hi, my name is Manny. I’m pretty much still new with owning a Jaguar. I
have
Can
Hi Paul.
You wrote:
<Certainly for a UK RHD car Circuit 1 Fuse Block is on the RH side (by
driver’s feet - directly under bonnet release catch)>
You sure about that? I recently had a Circuit 1 failure, and it was a fuse
in the (UK spec RHD) Passenger side door post fuse location. I thought the
electrics were all the same, LHD or RHD. The only thing I am careful about
is ‘Driver side’ and ‘Passenger side’ on USA cars. I always say ‘RHS
looking forwards’ or whatever.
Cheers,
Chris Dupres
'88 Sovereign
Surrey, UK
modern@jag-lovers.orgOn Sun, 23 May 1999 17:58:13 -0400, Chris Dupres
chris_dupres@compuserve.comwrote:
Hi Paul.
driver’s feet - directly under bonnet release catch)>You sure about that? I recently had a Circuit 1 failure, and it was a fuse
The one I fixed yesterday was a Circuit 2, and was in the LH
(passenger) footwell. This is as per the handbook (I checked, before
risking checking all the fuses in the wrong box).
BTW it was the aircon LH blower fuse (20A), and it doesn’t seem to
have blown again, so it may have just had a bad day.
Phil Lee, Bordeaux '88 XJ40, 153,000 Miles.
Cambridgeshire, England.
Hi Chris
For a moment I thought I was going crackers and couldn’t even copy the
answer correctly from my Jag Service Manuals (proper Jaguar Cars version).
I’ve just been outdoors to the car, switched on and pulled a RH side fuse -
what did I get? ‘Circuit 1 Failure’ !!
Where do we go from here?
Paul '88 XJ40 Sovereign. London NW7.----------
To: INTERNET:@Paul_C_Lee
Cc: Jaguar mail group modern@jag-lovers.org
Subject: Re: [modern] Circuit 1 failure
Date: 23 May 1999 22:58
Hi Paul.
Cheers,
Chris Dupres
'88 Sovereign
Surrey, UK
Bearing in mind that mine is a UK market RHD '88 Sovereign, built late
March/early April '88 and bought by my late father-in-law mid-April '88,
VIN 548 664, the answers to fuse locations, values and functions are as
follows:
(note that the fuse blocks of Circuits 1 & 2, at floor level just forward
of the front doors, have 14-fuses in 2-vertical coulumns of 7-fuses to
each, numbered for each fuse block in all references as 1 - 7 for the left
hand column & 8 - 14 for the right column & both reading top to bottom)
Circuit 1 (RH side of car)
#1 - 15a - Right hand door (window, door guard lamp & mirrors if driver’s
door)
#2 - 15a - Door lock control, luggage compartment lock, petrol filler cap
#3 - 20a - Right hand air-con (where fitted) / heater fan
#4 - 15a - Right hand main beam headlamp
#5 - 5a - Right hand front lamps (side/side marker, direction indicators &
repeater)
#6 - 20a - Heated rear screen,luggage compartment lamp, electric aerial,
heated door mirrors & rear quarter reading lamp (RH)(where fitted)
#7 - 10a - Right hand rear lamps (stop, reverse, direction indicators & fog
[where fitted])
#8 - 20a - Front & rear cigar lighters (where fitted)
#9 - 5a, 10a or 20a - Electrical accessories (only supposed to be fitted by
Jaguar Dealers !!)
#10 - 20a - Radio, sun roof, heated door locks (where fitted), glove
compartment lamp, map light, interior headrest lamps, ‘state’ illumination
#11 - 15a - Cooling fan, air-con. compressor clutch (where fitted), under
bonnet lamps
#12 - 3a - Right hand rear lamps (tail, number plate & side marker)
#13 - 15a - Right hand rear door, window, door guard lamp
#14 - 10a - Right hand dip headlamp, fog lamp (where fitted)
Circuit 2 (LH side of car)
#1 - 15a - Left hand front do or (window, door guard lamp & mirrors if
driver’s door)
#2 - 3a - Instrument pack
#3 - 20a - Left hand air-con. (where fitted) / heater fan
#4 - 15a - Left hand main beam headlamp
#5 - 5a - Left hand front lamps (side/side marker, direction indicators &
repeater)
#6 - 3a - Ride levelling (where fitted), power brakes
#7 - 7.5a - Left hand rear lamps (stop, reverse, direction indicators & fog
[where fitted])
#8 - 25a - Right hand seat movement (where fitted) & seat heater (where
fitted)
Jaguar Dealers !!)
#10 - 25a - Left hand seat movement (where fitted) & seat heater (where
fitted)
#11 - 20a - Windscreen wiper, horns
#12 - 3a - Left hand rear lamps (tail, number plate & side marker)
#13 - 15a - Left hand rear door, window, door guard lamp, fuel filler cap,
rear quarter reading lamp (LH)(where fitted)
#14 - 10a - Left hand dip headlamp, fog lamp (where fitted)
Circuit 3 (Centre armrest - numbering right to left)
#1 - 3a - Lamp modules right hand rear & left hand front, alternator module
#2 - 3a - Lamp modules right hand front & left hand rear
#3 - 5a - Speed control (where fitted)
#4 - 3a - Power brakes, ride levelling (where fitted)
#5 - 3a - Cooling fan, heated washer jets
#6 - 3a - Radio illumination, breather heater
Hope this may be of some help - all data taken from original Owner’s
Handbook & labels on fuse block covers, both of which tally with one
another (surprise!)
To: @Paul_C_Lee
Date: 23 May 1999 16:00That would be greatly appreciated. Thanks, Paul. I’m on my way to Pep
Boys to
buy some fuses.
