I believe it’s normally open - this is fail safe ( can always get heat for
demist etc ), and also some models didn’t have the valve but relied on the
blend flaps to perform the temperature control.
Cheers - Jez> -----Original Message-----
Sent: 24 February 2002 00:10
To: modern@jag-lovers.org
Subject: [modern] heater valve…normally open??? normally closed?
Good Day eh!
Well, its time to replace the heater valve. Removed mine and found
absolutely no internals…that must be why it doesn’t stop
the flow !!
(brilliance is one of my strong suits)
Anyways, reading the archives, i am lead to believe that the valve is
normally open…and that a vacuum is required to close the
valve. Down I
go top my friendly neighbourhood auto parts guy to find a non-Jag
replacement. In HIS book, however, (two seperate manuals actually) the
Jaguar heater valve is listed as a “vacuum to open” style
valve (little
picture in book shows my valve)
So, question is…:
Is the valve “vaccuum to close ie…normally open” or is it “vacuum to
open…normally closed”??? The archives disagree with the manuals.
Oh, my car is the 1988 Sovereign, 3.6 litre…and…if it makes a
difference…the seats have a tear in the piping…(not sure if that
reflects on the proper valve choice or not)
(On a side note, it seems there is a very popular vlave used by GM for
the buicks and caddys which seems to be the right size etc as a
replacement for the jag valve…and its about $30 cdn…compared to
$107 cdn for the real McCoy…)
Thanks in advance!!
Darren Bessey
hbrewer@golden.net
Important. This message is intended for the above named person(s)
only and is confidential.
If you are not the person named above or the intended recipient
and have received this message in error please accept our
apologies. Please do not copy it or show it to anyone else. If you
received this message in error, please telephone us on
(+44)(0)1932 404000 or email Helpdesk@Easynet.COM
Then, please delete this message. Thank you.
Because internet communications are not always secure the
recipient is responsible for verifying the origin and authenticity
of the content of this message before acting on its contents. All
contracts must be in writing, signed by an authorized officer of
Easynet Telecommunications Limited. All orders must be placed
on Easynet Telecommunications Limited standard hard copy form.
Please note that Easynet Telecommunications Limited may
monitor e-mails and other communications passing between
itself and any other person.
