Hello all,
Does anyone know of a website or other that sells the high-pressure hoses
(2) that run off of the mineral oil reservoir? It seems that both of the
hoses on the 91 VP are original and both seem to be weeping. They aren’t
leaking profusely, but overnight they seem to seep a good bit of fluid out
and I’d like to change them out. I know they’re pretty costly and I was told
they could be fabricated for a lot less. Anybody got any leads?
Thanks so much!
Funny you should ask this question, mine went over the weekend in
spectacular fashion. Be careful when ordering as they changed at a certain
chassis number as I found out to my cost. 20 miles from the nearest dealer
and I got supplied the wrong part. On the plus side I was charged about �8
so it was not too unreasonable. Make sure you have plenty of HSMO before you
start.
Best of luck,
Dave Powell,
Senior Solutions Consultant
Aspect Communications UK Ltd.
Direct tel. 020 8589 1129
Mobile 07799 071129-----Original Message-----
Sent: 08 April 2002 14:44
To: Modern@jag-lovers.org
Subject: [modern] High Pressure hoses
Hello all,
Thanks so much!
