Hi there,
Anyone have any tips on how to remove a (modern) radio from a Mk10/420G? I need access to the rear of the wooden panel but not sure how to remove the panel that the radio is attached to/sitting in.
Hi there,
They normally come with a pair of thin steel strips which you insert down the sides of the radio to release the clips that are holding the radio in.
Thanks, I got that far, but how do I get the wooden panel off?
Hard to say then, can you post a picture?
Doh, there is a screw on the bottom and then the panel pops off two pinch bolts at the top.
Good to hear a resolution.
