Hi. This is the qmail-send program at cask.force9.net.
I’m afraid I wasn’t able to deliver your message to the following addresses.
This is a permanent error; I’ve given up. Sorry it didn’t work out.
0@cask.force9.net:
Sorry, no mailbox here by that name. (#5.1.1)
— Below this line is a copy of the message.
Return-Path: <@Stephen_Taylor_VBE>
Received: (qmail 22312 invoked from network); 17 Aug 1999 15:57:01 -0000
Received: from unknown (HELO leekes.co.uk) (195.166.134.150)
by cask.force9.net with SMTP; 17 Aug 1999 15:57:01 -0000-----Original Message-----
[mailto:MAILER-DAEMON@cask.force9.net]
Sent: Tuesday, August 17, 1999 5:58 PM
To: Stephen Taylor (VBE)
Subject: failure notice
Date: Tue, 17 Aug 99 16:51:49 +0100
Subject: RE: [modern] As I was driving home…
Sender: “Stephen Taylor (VBE)”<@Stephen_Taylor_VBE>
To: <0>
MIME-Version: 1.0
Brett,
Your comments sound very reassuring. I’ll let you know what’s found after
the head is removed tomorrow.
I wasn’t really on vacation, just a long weekend trip.
Stephen
From: Brett Gazdzinski [mailto:Brett.Gazdzinski@wcom.com]
Sent: Tuesday, August 17, 1999 2:30 PM
To: Stephen Taylor (VBE); Modern@jag-lovers.org
Subject: Re: [modern] As I was driving home…
Stephen,
Very sorry you had such problems on your vacation!
It sure sounds like the shop that did the work on your head did not
set the valve lash correctly, or, did not check for a warped head,
but I would guess you have two burnt or stuck exhaust valves…
one in each cylinder.
Since you don’t mention coolant leaks, or overheating, its the valves
and not the head gasket.
Is 90 mph pushing the 3.2 engine?
My 4.0 likes cruising at 90 or 100, 120 would be pushing it for long
periods, (top speed is about 140?).
I suspect the shop left the lash a little tight, and you pushing the
engine at 90 mph pushed the exhaust valves over the melt point.
I would ask for the shop to make it right…point out your relaxing
vacation was spent dealing with the results of their work…
Brett
