I tried the NGK plugs in my '95 XJR - ran as smooth as can be imagined for
about 1000 miles, then went to behaving like the old Champions, then
developed a real bad misfire when starting from hot. Put Champions back in,
the idle was never quite as smooth as the new NGK’s, but no misfires after a
lot of miles.
Jaguar changed the recommendation for the AJ16 engine from RC9YCC to the
slightly hotter RC12YCC, which is said to improve the idle, so I’ll try
those next time.
Cheers - Jez> -----Original Message-----
From: Brett Gazdzinski [mailto:brett.gazdzinski@wcom.com]
Sent: 08 January 2002 14:38
To: modern@jag-lovers.org
Subject: RE: [modern] spark plugs
I have Champion rc9yc plugs in my car now…I think that’s the number.
I have never had a problem with them, even when they get very old.
I did try the bosch platinum plugs…single electrode ones.
They set the check engine light, ff26 I think it was.
I tried some sort of NGK v groove plugs, and almost failed
the emissions test, but no codes were ever set.
I tried some ngk platinum plugs, but I think they were the wrong
heat range as they ran black.
I think I tried the bosch plus 4 (4 electrode plugs) and did
not get a check engine light, but no improvement over Champions
and I did not get the emissions tested.
Its interesting to measure the differences between plug brands.
You can measure the resistance with a DMM.
From what I remember, the ngk plugs had a lower resistance
then the Champions.
I should compare them all…
I tend to think its a good idea to replace the plugs every year.
On the AJ6 engine, they are right there, and replacing them ensures
you will be able to get them out, and you can inspect them for
looks.
On some cars that come with 100,000 mile plugs, you may not be able
to remove them without damage to the head after 100,000 miles!
On cars with hard to get at plugs, the platinum plugs are great, as you only need to get at them rarely. I would suspect something is wrong if you have a plug that fails in any reasonable amount of miles. I imagine the regular Champions in the AJ6 engine would go about 50,000 miles without trouble. When I got my car, the original plugs were very worn. They MAY have been the original plugs installed at the factory, well worn at 70,000 miles. I took them out and put in the bosch platinum plugs. Nothing but the best for my car! After a week, the check engine light kept coming on. After fooling around with things, I tried the old worn out Champion plugs. No problems at all. It may be that if you gap them, they may go 100,000 miles. They may have only nubs left, but seem to work ok… Brett 1990 XJ6 Dougie, Under what conditions are the spark plugs failing ? I have been using NGK’s in my 2.9L for some 43k+ miles, so far withhout problems. They were available at reasonable cost from my source, otherwise I would have fitted the recommended Champions. Brett G has reported that more expensive type plugs have not been satisfactory, in his larger engine variant, and that the recommended Champion units have proved to be trouble-free. Others, also with the larger engines, have reported problems with costly plugs as well as NGK’s. As I write this, I can not recall the precise Champion plugs reccommended for my 2.9L, (NY3C / 9C ??) but the information is on a clear label set on the top of the LHS wing / fender valance on my RHD car. Why not try the manufacturers choice. Kind Regards, John Tarrant. Dougie wrote
<Can anyone suggest the best spark plugs for a 2.9 XJ40? I’ve
been using
NGK’s but they seem to be breaking down.>
Important. This message is intended for the above named person(s)
only and is confidential.
If you are not the person named above or the intended recipient
and have received this message in error please accept our
apologies. Please do not copy it or show it to anyone else. If you
received this message in error, please telephone us on
(+44)(0)1932 404000 or email Helpdesk@Easynet.COM
Then, please delete this message. Thank you.
Because internet communications are not always secure the
recipient is responsible for verifying the origin and authenticity
of the content of this message before acting on its contents. All
contracts must be in writing, signed by an authorized officer of
Easynet Telecommunications Limited. All orders must be placed
on Easynet Telecommunications Limited standard hard copy form.
Please note that Easynet Telecommunications Limited may
monitor e-mails and other communications passing between
itself and any other person.
