Hi there,
From my experience with BMW steptronic shifters, you really don’t need
to look at the display. After the first hour of driving the car, you
will know from your speed and the sound of the engine which gear you’re
in. In either case, the BMW system and most other similar systems will
not allow you to go down if you over-rev the engine… so if I’m going
to pass someone, I just keep pulling back at the gear and it will go to
the lowest gear! Furthermore, the kickdown overrides and will simply
throw the car back in the lowest gear possible once depressed… The
nice thing about it is that you can shift up whenever you like and that
gives you the feeling of more control.
I agree with you concerning the new 7 series shifter! I think they’ve
gone back a few years (maybe 30) with that shifter - at least the
placement of it - certainly technology wise, it is more advanced than
any automatic shifter sold today (with 6 forward gears, etc.) I think a
floor mounted shifter would have been nicer!
Abdullah
95 XJR-----Original Message-----
From: owner-modern@jag-lovers.org [mailto:owner-modern@jag-lovers.org]
On Behalf Of Pascal Gademer
Sent: April 17, 2002 4:51 PM
To: modern@jag-lovers.org
Subject: Re: [modern] Survey on J-Shifter
you’re right… I’ve often mentioned that as well… but I guess
those
journalists are impressed by fancy electronics or want to feel like
Michael
Schumacher…
the J Gate does somethign none of the other system provide : instant
feedback thru the position of your wrist… no display to look at…
I always use it, it’s great especially to downsfhit. The only thing
missing
is a way to force an upshift so for instance, in town, I’ll select 3rd
at a
light and trigger the upshift with the throtle. then down shift to
second
coming near the next stop…
On highway, you can downshift before passing so that you bring the revs
where you wnat them for max power. If I’m looking at the road ahead the
last thing I want is to have to look down at the display…
I remember some fun driving on some tight canyon roads in the Texas hill
country during the Texas 2000, tight roads considering the size of the
XKR,
where I spent period of times acelerating out of bends by preselecting
the
highest gear I’d need, triggering with the throttle, then jumping on the
brakes and downshifting back to 2nd… it was heaven !
It’s encouraging that Jaguar kept it on the revised S, I hope they on
the X
350. I’ve seen pictures of the BMW shifter on the new 7 … it looks
like a
turn signal thingt on the steerring column… with small digits on the
dash… is that progress ?
Pascal
----- Original Message -----
To: modern@jag-lovers.org; xj-s@jag-lovers.org
Sent: Wednesday, April 17, 2002 4:28 PM
Subject: [modern] Survey on J-Shifter
Dear Lists (maybe pass this onto lists outside modern and xj-s):
Sorry for cross-posting, but I am pretty non-plussed again about yet
another
auto magazine bad mouthing the Jaguar J-Gate shifter. Specifically,
the
May
2002 Car and Driver, page 42, when they opined:
