Anyone know off hand what size the nut is on the front wheel hub? I need
to tighten the bearings and need to make sure I have the right size before
I pull everything off.
Thanks in advance.
Gordon
'97 XJ6L
Thanks in advance.
Gordon
'97 XJ6L
Gordon,
The new cars must be different than the old ones,
as you would never use a socket/wrench on the nut,
as its not supposed to be tight, only snug.
I use a pair of pliers to tighten mine…
It comes off by hand…
What sort of setup did they go to, one like the rear
wheels with a shim and spacer?
Brett
1990 XJ6>
hub? I need
right size before
I pull everything off.Thanks in advance.
Gordon
'97 XJ6L
Actually there is a cover that goes over the nut to install the cotter
pin in for fine adjustment
Jay
Brett Gazdzinski wrote:> Gordon,
as its not supposed to be tight, only snug.I use a pair of pliers to tighten mine…
wheels with a shim and spacer?Brett
1990 XJ6Anyone know off hand what size the nut is on the front wheel
hub? I need
right size before
Gordon
'97 XJ6L
