Removed and replaced the CS bracket on my '97 X300, 4.0 ltr.
The new bracket is made by Andy Stodart and is intended to advance the timing by 5 deg.
The bracket is well made and easy to install.
I used a 1/4" drive ratchet and a long extension to remove the 8mm bolt that holds the sensor.
Then a 10mm socket with no extension to remove the two bolts holding the old bracket.
Cleaned everything, especially the round sensor which is a tight fit in the new bracket.
Started right up and runs great. Will report back when I have data on mileage and power.
Andy and his Wife, Helen were super to work with and the bracket arrived within a few days.
His email is: andystodart@metronet.co.uk
Tom Roorda
Olympic Peninsula of Washington State
1997 X300
