I have my fathers 1966 E-type to move thats been parked for 15 plus years. Front brakes I just loosened the caliper halves. Rear not so easy.
I tried drilling the pad material away to break thinks loose but no luck. I think I need to look at parking brake pads as well. Has anyone moved an E-type on dollies up on a trailer. I would remove dollies after it is loaded.
Also is there a good spot to pull the car up front as I don’t want to damage anything?
When I bought my car the brakes worked marginally but I found the rear pads to be stuck in the calipers. I was able to remove all 4 rear pistons from the calipers without dropping the IRS. I ground down a cheapo 1/4 inch drive socket to put on a low profile swivel handle to fit between the differential and onto the bolts holding the inboard pistons to the caliper. Might be an option to move the car around without dropping the IRS. Here is my socket and handle…
FWIW, when I extracted my EType from the building where it had sat for 25 years, we pushed it on dollies until it was close to the door it was going out. Rear brakes were stuck. Took it off dollies and then started to winch it backward onto a flatbed, figuring the tires would just skid. Once we started to winch it the rear brakes freed up and it rolled freely.
FYI, I did the same as Scott, I winched out a roadster that had not moved in 30 years…slowly all of the wheels broke loose. Did not try the dish soap idea, but will next time, good luck. Jeff S. Atlanta, GA
When I blew the diff on my XJR it would roll forward but not in reverse, it was dropped off on my drive and had to be moved down the side of the house, this entailed a tight sweeping 90 deg bend on a downhill run. I managed by running a trolley jack under the diff and with a person in the car steering and braking we managed to slowly inch the car down into a position where I could park the car and work on the diff.
Similar to other experiences -
When I went to pick up my dad’s ‘68 the rear brakes were stuck. A slight pull with an ATV through some straps on the rear wishbones (I had to pull it backwards) and the brakes broke free. Be sure the handbrake is released first, of course.
