on the left side of the dash (you can only see it with the drivers door open there is an on off switch.does any one know what its for?
None that’s I was aware of when I had my ‘40, can you post a photo?
You have to open the door to see it it’s at the very left and of the dashboard on the driver side
Definitely sounds like an aftermarket add-on, maybe an alarm or kill switch? Have you tried to follow the wires from the switch?
Yep aftermarket DPO fitment.
not yet i just saw it today.i will turn if off tomorrow and see if it still starts.if it is a kill switch it pretty conspicuous. plus it does not look aftermarket it looks factory.
it doesn’t look aftermarket . i am just gonna turn it on and off while its running and see what happens and the same with just the key turned on.also i have a red blinking light that stays all the time i assumed was an alarm but i did not know how to use it.is that factory?its kind of on top behind the steering wheel ,i will see if this turns it off
