Oops - the engine I bought and rebuilt has parts missing in it’s carbs.
Am i right that from the pictures following parts are missing:
Jet holder with o-ring
Jet valve
Jet tube (seems to be missing on one item)
Did i miss something ? Should I order jet valves measuring the needle diameter before or should I replace the needles as well (do not look worn) ?
Is there some bracket between the float and the valve that is missing ?
Thanks a lot for your advises !
Tom
