Sounds like a parasitic draw.
Here’s some steps on how to find it. I’m lazy and didn’t read the whole thread.
Step 1: Prepare for Test
You should have a fully charged battery before starting – voltage would be around 12.6V for a good one. Be sure to close all doors, turn off the radio and disconnect accessories, such as smartphones and add-on GPS devices. Even a key in the ignition can have systems waking up on newer cars that will initiate draw.
Step 2: Disconnect the Battery
Pop the hood and disconnect the negative cable from the negative battery terminal. It is always best to do a parasitic draw test from the negative side so there is no chance of accidentally shorting should you test from the positive side.
Step 3: Connect the Multimeter
Plug the black probe into the common ( COM ) jack input of the multimeter and the red probe into the amps (usually A) jack input. Then connect the red probe to the previously disconnected negative cable of the car loom, and the black able onto the battery terminal.
Note : in order to test for current, the multimeter must be connected in series with the circuit as it needs to gauge electron flow, so to speak. Voltage, on the other hand, is measured in parallel.
Step 4: Give the Car Time to Sleep
Modern car systems may ‘wake up’ when you connect a multimeter in such a fashion as it picks up the power of its batteries. So wait a few minutes before conducting the draw test.
CAUTION : when connected, avoid starting the engine or even turning on the headlights as this will likely blow a fuse in the multimeter. Vehicle batteries put out a lot of amps due to being low voltage.
Step 5: Reading the Meter
Newer, auto ranging multimeters will automatically select the correct range of a signal they pick up. On manual ranging meters, you will need to select a range, usually either 2A or 200mA. If you get ‘OL’ on the screen, it means over limit and you should select a higher range.
If you see a reading of around 50mA and above on a standard car, it generally means something is drawing power and you likely have parasitic draw. Just note that if you have a big, modern, luxury car its added computerized systems will likely increase the natural current draw. In this instance, the threshold might be 100mA.
PARASITIC DRAW ESTABLISHED
It is now time to see what is causing the draw. The tried and tested method is to start pulling fuses to see which circuit is the culprit.
Step 6: Pulling Fuses
Locate the fuse panel(s) and start pulling out fuses one after the other, taking notice of any drop in the reading on the multimeter. If there is no joy with the fuses, start removing the relays. For those fuse boxes that are inside the vehicle, a tip is to lay the meter on the windshield facedown so you can see the display.
Step 7: Narrowing Down
When the display drops to a nominal mA draw, note the fuse/relay position number and check the vehicle’s manual. There is often more than one circuit on a given fuse, so you would then need to eliminate each one, such as remove a bulb or unplug a heater.
Step 8: Repair and Reconnect
When the meter drops down to 25mA or less after removing the offending fuse, bulb or unplugging a circuit, you likely have your culprit. Repair the fault/replace the item and run another test to be sure. If you’re confident there are no other faults, reconnect the battery.
Alternator fault? : if you’ve gone through all fuses and relays (and checked for other fuse boxes), oftentimes the alternator can be at fault. One of the diodes may have shorted out and caused current to drain back to the battery. Test it with the multimeter before and after unplugging.
