I inspected and drove this car recently. I have information that bidders would want that is not described. . Should I comment in BAT? Or should I give my contact info there and let them contact me? Would BAT remove my post?
Doug
Doug, the BaT Peanut Gallery and potential bidders revel in first-hand experience on a particular car. As long as you donât aim a shotgun at the sellerâs integrity and stick to facts, your post will not be removed. On the contrary, the BaT community will be very much appreciative.
Doug, unless you know something I donât, I donât think you can leave contact information in a post on BaT, so, as Tom said, just post you findings. That being said, Iâve seen guys post their names and business websites, enabling contact, but the rest of us canât seem to do it!
I would be interested in your observations.
Jagnoe
Doug, I assume âcarmdâ is your moniker on BaT. If so, I responded to your salient observations. My guess is this car needs work, as I think you also surmised.
Why not post a link?
Like this:
Thanks very much !!!
Dave
Since your warning, the bidding seems stuck at USD 55.500.
There have been additional comments requiring clarifications about the issues you mentioned, with the seller claiming to be âoffended by [your] comments questioning my integrityâ.
Not a good attitude imho to convince biddersâŚ
Not seeing anything that jumps out. Nice key fobâŚ
From what I see it has a Lot of potential, the Body seems dead straight and all orig. the Engine issues can be repaired . it would be an excellent driver ⌠My 2 cents
It seems worse than that to me as he appears to be blaming @carmd for disconnecting the wire to the fan. I would be very leery of this seller. JM2CW
Cheers,
LLynn
I posted the inspection and drive result I found on BAT. The fan did not run despite temp over 90C. I pulled the leads off the otter switch and jumpered them together with a paper clip, with the owners permision. The fan still did not run. I put them back . I saw the video just posted. It didnât capture the sound of the trans or engine noise I heard
What circuit do the fans in S1 use? Could fan issue be a fuse? Then a question⌠what is the âsilver dollarâ shaped thing on the oil sump. Is it an alternative plug?
I believe one of the reasons buyers sometimes pay a âpremiumâ for a car that is sold on BaT is for input other knowledgeable people make about a car. That is particularly helpful when a buyer is considering a car several states away. Awhile ago I went and looked at a car for sale that was local to me, and posted my observations for an interested party. The car was as presented, drove lovely, and the owner was very straightforward about what the car was, and was not.
My take away from this is that if someone has a car that they want to sell, and be upfront about its condition, BaT is a good venue. If they want to try and pass something over on somebody they tend to go to eBay instead, where âbuyer bewareâ seems to be the standard.
It has any expanding rubber bung in the oil drain plug area, obviously the drain plug stripped
Really
Thatâs what you can see so what else , mechanical stuff is small potatoes in the big picture especially doing it yourself
I thought the chrome looked âŚâŚ aged
