New engine--Another V-12 vs Chevy small block
Hello. I was going to do the LS swap but decided against it. I wanted to use an LS-3 for the power but they are just too expensive and I wasn’t going to dump another $10 in the car. For a driver and good power just find a used GTO drivetrain complete with trans . an LS-1 is powerful enough and reasonable. As far as the kit, go with Andrew at jag specialties. HE is a good resource to answer questions and has the gages figured out to work. . 2nd alt is Johns cars. I have dealt with John for 20 years. He knows these cars inside and out. He also has parts. He can supply an LS mounting kit to get the engine in the car but I don’t think he has developed anything else. HE has done mostly LT-1’s and small blocks with carburetors.
Andrew at Jag specialties really has this figured out. If you go with Johns, you will have to spend a lot of time fiddling around. Make sure that you get a ‘complete’ running pullout engine/trans/ Otherwise the conversion becomes difficult.
One key item. Make sure that you have good grounds everywhere with the wiring. It played hell with me on my last conversion. Jag electronics don’t like missing or loose grounds. Everything goes haywire.
It’s a lot of work and its not simple but if you take your time and ask questions it will move along. They hard part is pulling the old engine, cleaning and installing the new one. Once you get past that, its just a lot of fiddling getting it all connected.
Marty
Thanks for your feedback Carl. The jag world is a new universe for me.
Craig
Marty,
This is invaluable advice for me, a novice in the jag world. My wife’s
car needs a lot of tlc but is just too beautiful to junk. Thanks so much
for your input. I might be back for more guidance from you and others as
we move forward.
Craig
So please share where you found a 5.3 V12 for 2500.00. Bought my 89 new engines shot want to stay true to form.
Thank you
