Hi, i’m Francesco Sapienza from italy.
I bought an xj6 series 3 4.2 a while ago, it had a blocked engine, because cyl 1 was stuck due to corrosion made in the years the car stayed unused.
So i rebuilt the engine (bore, new pistons, bearings, valves, guides, face milling, ecc)
Now the engine is on the car, and everything is fully assembled, the only problem i’m having is:
The engine once started revs to 1200-1300 as it should, it seems smooth, but when the aav and the start injector closes (as they should) the engine wants to go to 800/900 revs (as it should), but while rpm lowers to idle it starts to misfire, so it can’t hold idle and goes to rough idle till stalling.
If i push throttle a moment it revs up, but if i keep pushed at a certain value it dies the same.
Now: I’d exclude the fuel line, because the pump is new, the filter too, the injectors had been refurbished just today, and if i remove a tube from the filter or somewhere else, the fuel that comes out is clean.
I’d exclude the ignition timing too, because turning the distributor didn’t change anything and I assembled it with the same orientation it had before disassembly.
The throttle body is registered to it’s correct opening
The maf looks like was not opened
The temp sensor nearest to firewall works, because if i disconnect it, the problems goes worse
Tested quite all the vacuum line but seems to be ok
I’ve done a lot of tests but nothing changed anything.
The only things i’ve not changed or refurbished are the coil and the distributor cap.
May those two components be the cause? Consider that when the engine manages to rev up somehow it seems smooth.
It only has problem at steady throttle, idle or not.
