After a couple of minutes I was greeted by literally clouds of smoke, billowing out of the exhaust.
Then I remembered new fuel tanks are coated with a wax inside and I had not removed the protective coating internally.
I drained and refilled the tank, no difference.
The engine oil was clear, the coolant clear and up to the level in the expansion tank.
Crack in the head? Crack in a liner? What could it be?
Then I noticed a small pool of black oil under the car. The torch showed it was coming from an exhaust join on the RHS. Oil from the exhaust!
The I remembered, that exhaust was newly fitted to a track car that blew up its engine. It has been in my store for 2 years.
The exhaust was full of oil.
Thank goodness.
Tomorrow I aim to drop the front ride height by 2 inches.
Wait 60 years for it to sag a bit. The top of my wheel arch is level with the top edge of the wheel rim. Car sits level and it’s lower than it should be, but I like it that way.
Morning Serge.
No, I will just reset the torsion bars.
I must have got it wrong on the first place.
It is so high at the front that my guess one whole click on the rear ear will bring it down where I would like it.
So I will not have to tap the torsion bar forward. Thats the plan.
Agreed: this was how the suspension got set on Tweety, back when he was still a racecar. Worked just fine on the street and I much preferred the appearance.
So it does. Low is good for looks and track handling, less so for traffic calming devices of the kind I encounter when I take my (slightly low) E for a bimble. Originally my E rode too high. Massive understeer. Wouldn’t recommend it.
James, Off your subject but I’m a member. It’s been over a year since I’ve use the JL site. I’ver created to mesaageI budt cannot determine how to send it. I see no place to ‘sign in’ or a ‘send’ button. How do I do it? Thanks, James. Bert '67 OTS
It’s not intuitive.
1 - Go to a posting by the guy you wanna send a PM to
2 - Click on his Avatar (in James’ case, the circle with his face in it)
3 - In the upper right hand corner will be a blue box with an envelope and “Message”
4 - Click on it and off you go
