Solenoids. Interesting topics along with Bob’s comment on “starter weight”.
Paul: My “bugs” never had starter issues. Others, using the Delco Remy did have “hot start” crank issues. Not uncommon. I solved it in my Delco Remy cranked IHC Scouit II . I used a solid circuit relay sourced from a Mopar…
The issue seems to be inadequate volts at the solenoid atop the starter.
Some used a Ford style remote solenoid, wired in one way or another. Electricly, the solenoid is just a big relay…
Son and I just did another conversation as to the need for a relay on my Jaguar. My theory, Very 'delicate" ignition switch and small wires. Need more juice at the starter!!
Well my lump is back to a hissy fit. No crank issue, again. Came home from the market on a flat bed. I have a beef with the folks there, actually, the boss. I might have made my last visit there. another tale for another time and perhaps another place. Actually another beef as well. My cell let me down!!
Decades ago, I removed the starter from my IHC and took it apart. Hot crank time. It was just fine inside. But, I noted a contact disc plate that could be reversed to present a fresh face to the volts… Slick, indeed…
And, on one of my present diversions. You Tube.
Two teams competing to restart two junk yard derelicts.
Each late 40’s cars. One a Buick straight OHV eight, the other a flat head Packard straight.
Interestingly, the Packard’s starter was the classic Delco Remy. Relevant? Same architecture as Lucas!!Very crusty and struck. The team took it apart and cleaned it up, Freed, Applied power, passed bench test !! Will it crank the “refreshed” straight 8? Will they beat the Buick team? , Next coming up…
Carl
