So, now for the minor update i found out today.
I decided to remove the SUs again and put on the bench, i was watching some interesting SU videos last night on YT and began to question had the needles been changed or perhaps not equal to each other.
I also did as david mentioned is spray the linkages with parts cleaner and see if there was any change. much to my surprise there was a change to the rear carb. i had inspected the linkage for excessive play when i first pulled them off the engine and wouldnt have said it was excessive, but clearly there was an air leak.
i had the CSK38 service kits from Midel that came with replacement shaft seals etc, so i went about pulling it all down again and cleaning the shafts up and resealing with the new type viton seals. most definitely that has helped steady the idle. but more to come as i found.
i removed the pots and did the drop test of the slides blocking the holes, both sus drop at the same rate so that was good.
i also found from the video i saw, that when the pots are internally vented the caps dont need to be vented with the tiny hole, my front SU doesnt have a vented cap, where the rear one does. I thought i would trial sealing the hole and see what happens. More to comeā¦
I also removed the needles to see what they were. Both were UM needles which the book states are STD needles for HD8. but, one needle was half a mm further protruding. i got the verniers again and reinstalled them equally and moved on with the reassembly stage.
installed back onto the engine and with semi happy news the erratic/irregular/hard to chase, idle has improved.
i actually manage to have the engine idle at 900 rpm, for a short while smoothly before it would develop a little choke and shake about a little, but noooo where near as bad as it used to.
i also managed to check static timing again with the vac hose off, it was about 8-9 degrees BTDC.
attempted to then slowly bring it up in RPM, where like always, it would fart around and start backfiring through the carbs at 2500 rpm, push it to 3000 rpm it would go off all the time, flames out the carbs.
fiddled with mixtures and it makes no change at all. its as if theres a limiter set for antilag at 2500 rpm. good for my rally car, not the jag haha.
which brings me back to wondering if the Goss replacement coil someone prior to me has installed, it actually breaking down under load. as ive gone around the moon 4 times now and still the engine farts around at that rpm rangeā¦
if its not mechanical mistiming it has to be something in the distributor timing and or components.
open for suggestions, im still trying to find my box with my datsun coils and dizzys so i can use one of those for a test
