I’m just catching up again, and I see you’ve tested some of the wiring, and had some battery problems, but now the car cranks freely but does not start and run.
- Before you doo too much more cranking, it may be worth putting a squirt of oil into each spark plug hole so that the rings remain lubricated. There is at least one instance of an engine being ruined in cool-air high humidity environment because the low pressure created in each cylinder dry-cranking caused the humidity in the air to fall out in the cylinder, and create enough light surface rust that it ruined the rings with repeated cranking (as the problem was being chased down.).
Re Timing… have you touched or adjusted anything? or were you just looking? Usually timing is one of the last things we’d move on to. But at 0deg on the timing marker (assuming no shifting in the balancer due to rubber deterioration) the engine is either 10 degrees past an ignition event, or 360 out from that. That means both the intake and exhaust valve should be closed.
How are you seeing the exhaust valve? Are the exhaust manifolds off the car?
Low fuel in a clean tank is not a problem as long as it fills the sump and maybe a few gallons. There has to be enough to keep the fuel pickup sock in the sump under gas at all times.
You checked the Om value across 5 & 19 to the CTS, and how did you do the test for continuity on 18? Ran a loop in the engine bay?
You have spark (assuming it’s correct) and air, which suggest you have no fuel for as of yet unknown reasons. And you have a fuel pump that continuously stays on? (a problem we may have to deal with later).
Regarding the fuel injectors. It might be worth buying a NOID light.
NOID LITE (BOSCH 2) | OTC Tools
You can get them in small kits on Amazon or Harbor Freight or other auto-parts tool stores.
Another option: use a test light:
The light plugs into one of the fuel injector plugs and blinks as the ECU pulses the fuel injector… OR… does nothing… if the ECU is either not firing the injectors, or the injectors have no power or no connection to the ECU.
At this point, we need to know if the injectors are firing, and are capable of being fired by the ECU.
As smartly noted by Aristides above, the ECU will fire ALL the injectors as a single burst when, with key-on, you turn the turnstyle to WOT engaging the WOT switch (assuming that’s working.) IF you hear all injectors audibly click, then the ECU is capable of firing the injectors, and the problem really likely goes back to checking the pin 18 shielded RPM wire again.
IF on the other hand, there is NO audible burst, then:
- The switch is broken (check)
- The injectors are stuck. (Get a cheap Amazon/Ebay connector and make a pigtail to a 9 volt battery and try it on each injector tap tap tap tap ing the connection VERY BRIEFLY to see if you can get them to work. ABSOLUTLY DO NOT HOLD THE CONNECTION)
- There is no power to the injectors (check)
- There is a broken connection to the injectors (we’ll address that if the other tests don’t work)
- The ECU has a failure.
~Paul K.
