I have an x308 3.2 97 Sport,
It has sat unused for a year or so but has been started a couple of times in that period,
I put a fully charged battery in it and it cranks fine but won’t fire,
I checked the shreader valve for fuel pressure and I have none,
I can’t hear the pump running in the boot with ignition on so I removed the white plug from top of tank to check voltage,
I’m only getting 0.5v with ignition turned on so I presume I should have 13v or so at this plug?
I am getting supply voltage at the fuel pump relay connections and I swapped the relay also to see if that helped but no joy,
Anyone got any ideas ?
Thanks
Malky
