While turning left (only) and accelerating from a standstill a knocking and graunching sound is emitted from the rear of the car.
Any thoughts what this might be or whether you have experience of this ?
Thanks
Phil
Check the splines on the hubs and on the wheels. Possibly one or both are worn.
I believe this same noise was just discussed on here. First check all your U joints and wheel splines, If all is found to be OK, then replace the differential oil with one that is rated for or contains a limited slip additive.
It was. Same original poster too - 17 days ago. Not surprisingly, all the suggestions about the cause are the same too…
