Noise within rear wheel area
After driving 15 to 20 miles I am experiencing the following: 1. When applying the breaks I hear a grinding or more like a rubbing noise.
2. It can be duplicated at a low speed & engaging the ebrake lever without applying break pedal.
3. Also, experiencing ( hard to describe), a clunking noise within rear end when driving on a curvy road.
4. I pulled both rear wheels, greased rear hubs along with all zirts, checked rear differential etc.
5. Bled & changed break fluid.
Again, noise only occurs after driving several miles.
Hello Todd - sounds like you might have a loose, or worn thin and warped, brake rotor - also sounds like you may have an e-brake pad out of adjustment or a brake caliper that is loose at it’s mounts.
In addition you might try prying on the brake rotor to see if it can be moved. The bearings on the side of the differential could be bad
Thx for all suggested information. You’re probably point blank on. Will check into it ASAP ! Again Thank You, Todd
