I am finally getting ready to tackle getting the heat shields installed (with the engine an manifolds in place).
This will be really fun (sarcasm alert). @WoodBoatChick advised me HOW fun this was going to be, especially w/only one normally functioning arm.
My question is: as I may be having this car judged at some point, and this is not an easy task, is this an item that they will deduct points for if non orig. setscrews are used here? This is not a project I want to tackle twice, so want to do it correctly the 1st time.
Below are the bolts I am in need of so if anyone has OEM willing to part with, please PM me and I will purchase them.
These are the items I am in need of:
(2) Setscrew - Hex head, 1/4"unf x 1 1/4", Bzp Finish
(1) Setscrew Hex Head - 1/4"unf x 3/4", Bzp Finish
(4) Setscrew - Hex head, 5/16"unf x 1", Bzp Finish
(4) Setscrew - Hex head, 5/16"unf x 7/8", Bzp Finish
If original bolts not required, I will get from local hardware store and call it good.
I was never marked off (that I know of) for having US capscrews on the heat shields. For fasteners, you just need to be sure of the correct type (hex, slotted, Phillips, Posidriv), and whether they are painted body color or plated.
That said, judging may very well now include fastener authenticity today.
Itās also going to depend on the judge Even if they are sticklers for the proper fastener they wonāt catch everything and those some of those fasteners are not in an āin-your-faceā position.
One option is to rob a hidden area of the fasteners wth the āproperā head markings and replace those with generic grade 5 fasteners. Use the good stuff where it can be seen.
You can reuse good condition bolts here as there is no great tension on them and provided the thread is okā¦ā¦on this year they are likely to be GKN ā¦ā¦ try dismantlers of jagsā¦ā¦ all the saloons had same bolts
I quoted a few paragraphs from the Series 1.5 Judging Guide.
Hope I extracted the relevant passages"
UPPER HEAT SHIELD HOLDING BRAKE AND CLUTCH BOTTLES:
Zinc (galvanized) plated shield mounted to sub frame holding asbestos insulation on manifold side. Translucent white plastic bottles mounted to shield with cadmium-plated bracket. Brake bottles have gray rubber caps cantilevered over wires. Electrical connection concealed beneath cap. No wires on clutch bottle.
Note: Chris Bron reports stainless steel - confirmation requested
Note: Brushed aluminum after market shields have been observed and are incorrect
Note: Air conditioned cars have pastel green ceramic resistor on semi-gloss black bracket with black oxide clips and semi gloss black AC dryer and bracket mounted to shield.
Note: Decal on heat shield above bottles (or above heater case) reads, āWarning brake system is filled with Girling Crimson Brake Fluidā¦ā¦.ā
