While not familiar with that model, I have found that any wireless dongle with an “ELM27” spec works across many platforms and apps.
This one doesn’t seem to specify that.
The ones I have purchased, for an iPhone, needed to work on WiFi, not Bluetooth. Android phones can do both WiFi and Bluetooth.
I purchased and have been using a cheapie ELM27 reader for many years without any issues. You won’t be able to read ABS codes, but it will reset check engine lights, reveal standard “p” level trouble codes, as well as show you various bits of info necessary to troubleshoot issues with the car, such as coolant temp, O2 readings, and so on.
That being said, I would advise to make sure you get something that uses the ELM27 protocol.
