ODB2 ELM327 scanner
My XK8 is from 1999 (original deliverd in Germany).
Is there a suitable ELM327 scanner for it which can be used to reset the messages on the display in the car?
Thanks.
I’ve successfully used the Torque Pro app with and Android phone to reset the codes. It was also able to pick up some of the ABS codes.
I’ve also installed an Autell X60 gauge (Amazon) . I did this to watch the coolant temps ( stock gauge is phony), but as a bonus this gauge also allows for reading many other operating parameters, plus you can also reset the codes with it. You can just leave it plugged in, and it will not drain the battery ( auto shutoff after 30 seconds).
