Hi all,
I checked the parts numbers and details from the Spare Parts Catalogues.
It would appear that there were only long(ish) cartreidges or “elements” as Jaguar / SS Cars called them on all six cylinder cars.
Pre-war and early post-war cars used an earlier type, but from 1947 when LHD production first began the Tecalemit filter was always the same throughout MKIV and MKV production: FG.2306.
For whatever reason my oil filter housing says: FG.2312, which according to GB Dönni’s e-bay webshop was the OEM oil filter for the six cylinder SS1’s.
https://www.ebay.de/str/jaguarclassic?_trksid=p2047675.l2563
So my guess is that in my case, as the engine was replaced by Hornburg in Hollywood, LA, with a LHD MKIV 3 1/2 Litre engine, that had the separate oil filter assembly and only the Relief Valve Housing on the cylinder block, they used an Oil Filter Housing that fit and was available, and it happened to be Tecalemit FG.2312 from possibly an SS1 or spare parts stock for an SS1 or some other British car that used that one instead of the slightly longer FG.2306.
And thanks Roger, I sent you e-mail about the part numbers.
I would need at least the Relief Valve Body C.1088/C.
But possibly also a suitable (long) Canister C.1089/A, if anyone knows a good source for one?
I’ll ask Worcester Classic Spares of course as well.
MKIV Engine No. S.26 →
FG2306 OIl filter element
C.1089/A Canister
49451 Valve, relief, assembly
C.1088/C Relief Valve Body
C.1088/D Washer (fibre) under Hexagon
C.1089 OIL CLEANER
MKIV Engine No. SL.1831 →
49451 / C.1709 Oil Cleaner Relief Valve Assembly
C.1710 Washer (Fibre) between Relief Valve and Housing
MKV
C.1089/A Canister
C.1087 Washer, Jointing between Oil Cleaner and OIl Gallery Plate
