After posting 2 pics had to wait 5 hours before next post, rules for newbies!
Steering rack is a pretty straight line all the way across to the steering arm however the ends drop about 3/4 of an inch from rack to arm.
If the rack were to be lowered and moved forward on its existing angle, probably about 2.5 inches the whole rack to steering arm would be more or less horizontal
Have taken more photos if needed but may be my last post
From the base of the block to the base of the 1”-wide central scavenge gutter is 6.75” compared to 7.75” on an E sump. It is angled up on each side and therefore tilting the engine is helpful, although the pump being on the left side means it becomes the low point.
The front section you were asking about is a hair over 5” compared to 6.25” on E and XJ sumps.
The external pipework visible is not bolted up yet and is more obvious on this engine than the neater standard dry sump pipework I have as spares. This is because I am using an alloy D cooler plumbed into the scavenge return rather than a modern higher- pressure rated cooler in the feed line. The D would survive normal use but I could imagine someone revving it high with cold thick oil and maybe bursting a seam.
So Peter, the oil pump is mounted on the left side of the block (the side we can’t see in the photo), and driven by a shaft that runs transverse across the front of the engine, is that correct, or is the pimp not yet mounted?
Yes the three stage Pace is bolted to a machined platform on the left side of the sump and driven by a toothed belt from the crank pulley. Neither are fitted to the engine yet. Belt tension is adjusted by shumming the pimp…
