I’m assembling my 1967 4.2 engine for my 420 sedan. I for the life of me get the oil pipes on without cutting the seals. I lubed them well, beveled and polished the end of each tube and still cuts them 3 seals total. I even applied heat the the oil pump to try to expand the aluminum slightly. Looking at my factory originals, they were cut but not as bad as my new seals. The suction seal fits tight so I removed the small piece of rubber that was cut and reinstalled. I will probably change that seal again. The oil pipe groove is cut with a slight bevel intended to be there to compress the o-ring some…
I plan on getting seals from work and match my old seals to the aircraft MS seals we have at the shop. Anyone use a sealer, lock tite or such as added comfort?
Second is the oil pump coupler supposed to float 1/8 inch? That’s how it was, but seems to be a shady design as it will favor the pump side.
